I have not been in there for a while so I'm going on memory. The headlights definitely were one wire to the left headlight and then across the front to the right headlight. This wire went to one end of the resistor--on High the voltage by-passed the resistor and went right to the pin. The two wires on the other side should be the flasher and the tail light. That pin gets 12V+ on both D and H but not R (or O, obviously). Then one pin and wire for the rear bright light and one pin and wire to the fuse.
If I did a rewire and it were not a show tractor, I'd just start from scratch with some split loom rather than making the wrong old harness work. I rewired mine from scratch when I was 17 and I'm 55 now and my old work has held up better than those IH cloth harnesses ever did. Plus it was easier to upgrade to an alternator and put in high wattage headlights.
This post was edited by TheDurk at 13:23:13 08/30/10 2 times.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
