100 jumps into 2 gears at once
Posted by couv on August 29, 2010 at 18:55:03 from (209.33.29.72):
Been a while since it did it, but grading dirt in 1st gear, under heavy load, 3-4 also jumped in, tries to run in 2 gears at once
Step on the clutch motion stops. Let the clutch out and it dies.
Pulled the trans-top gear shift off, re-aligned the 1-2 3-4 gear sets, back to work.
The shift rail for 3-4 was in "3", and had to forcefully push that rail to neutral to get everyting lined up.
Is this the "weld & grind the end of the shift lever" problem, or something else ?
