Re: 100 jumps into 2 gears at once
Posted by mkirsch on August 30, 2010 at 06:13:43 from (64.80.108.57):
In Reply to: 100 jumps into 2 gears at once posted by couv on August 29, 2010 at 18:55:03:
The "weld & grind the end of the shift lever" only happens when you're shifting.
If the tractor is popping into two gears all by itself while you are driving along, it is something else.
Frankly, I have never heard of such a thing happening before, so unfortunately I have no suggestions.
My gut feeling is that it's a MAJOR problem. Bad bearings or something, causing misalignment which causes the slider gear to "walk" into 3rd.
Today's Featured Article - Tractor Profile: Earthmaster - by Staff. This tractor, manufactured by the Earthmaster Farm Equipment company in Burbank, California was made for only two years. The Model C came out in 1948 and was followed by the "CN" (narrow-width model), "CNH (narrow-width high-crop model), "CH" (high-crop), "D" and the "DH" (high-crop) in 1949. The main difference between the models was tire size, tractor width and cultivating height. The "D" series were about 20 inches wider overall than the ... [Read Article]
