Re: Need Help quick on a 140 Motor/Water Pump Running - V...
Posted by Janicholson on August 30, 2010 at 12:55:30 from (199.17.6.223):
In Reply to: Re: Need Help quick on a 140 Motor/Water Pump Running - V... posted by AL Farmall Boy on August 30, 2010 at 12:47:36:
The starter relay has 4 posts. A large post, a post marked S a post marked I and a second large post.
The large post closest to the S terminal goes to the battery cable. The S terminal goes to the key S terminal for starting. The I terminal hooks to the coil, at the coil, on the input side of the coil not the distributor side. The last big post hooks to the starter. Jim
