Re: field terminal wiring on a 1948 IH cub tractor
Posted by John T on September 05, 2010 at 05:23:22 from (66.244.97.31):
In Reply to: field terminal wiring on a 1948 IH cub tractor posted by ejensen on September 04, 2010 at 21:01:04:
FWIW (not much actually lol) Im more in Jims camp then Genes on this one in that I would NOT connect the gennys Field post to BOTH FLD on a cutout PLUS any light switch terminal.
Seems to me if it has the original non lights set up and a cutout that has the FLD terminal, THEN IT SHOULDNT HAVE THE LHBD LIGHT SWITCH (or if it does simply DO NOT connect it to the gennys FLD). I view the LHBD switch for use on 2 wire (BAT/GEN) Cutout Relays but for older (NON light) 3 wire (BAT/GEN/FLD) cutout relays I just dont see (engineering wise) using any LHBD field resistor in addition the gennys Field wire to the 3 wire cutout. If you do then the 2 resistors in paralell (As Jim correctly noted) are less then designed for making the genny always charge at a higher rate possibly overcharging the battery.
I dont have any IHC specs but it just dont seem right to use BOTH a cutout field resistor PLUS a LHBD light switch resistor in paralell !!! if the tractor had BOTH a "true correct" LHBD switch PLUS a 3 wire cutout, Id use the LHBD ONLY as one can choose Low or High charge options
DO NOT confuse a VR here with a 3 terminal cutout yall
John T
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
