Posted by MeanGene1 on September 05, 2010 at 15:12:38 from (209.148.104.194):
My "new" 450 gas was leaking at the flange between the live pump and the steel hyd lines, so I pulled it apart this morning, the o-rings seemed in good shape, replaced them with standard o-rings which matched what came out. Still leaks just as bad, definitely leaking out between the flanges, not a cracked line, Are they standard o-rings, or a special size or type? I've run into quad rings and such before, and the flanges seemed in good shape and flat, seems like it should be sealing up if the rings are correct. I haven't found any kits for this application, does it just use standard rings? Hate to take it apart again to straightedge it, it's a booger to get lined back up with the solid steel lines
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
