Re: Water pump on H.
Posted by David A.. Smith on September 06, 2010 at 13:43:34 from (72.70.209.225):
In Reply to: Re: Water pump on H. posted by Janicholson on September 06, 2010 at 10:33:48:
Great. Thanks for putting my mind at rest. Now I can put the thing back together. Maybe you can also let me know if I only need to repack the very end of the sleeve where it widens about the shaft? I'm assuming so since the shaft fits pretty tightly for most of the length of the sleeve. Finally ... in the middle of the fan hub there's lots of room between the bushing that slides over the sleeve and the inner walls of the hub. When I took the thing apart there was nothing in this space. Should that be packed with greese when I reassemble? Thanks.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
