Re: Water pump on H.
Posted by Janicholson on September 06, 2010 at 14:32:22 from (199.17.6.223):
In Reply to: Re: Water pump on H. posted by David A.. Smith on September 06, 2010 at 13:43:34:
There should be a grease fitting (usually with a screw on cover) on the hub If this attaches to the Vid space, I think it could be packed with grease (I like mobil1 synthetic chassis grease). I cannot remember exactly where the void is. The packing goes only in the flaired ares. behind the packing nut. Tighten the nut pretty hard (enough to make it turn hard enough to not spin after it is spun by hand) then back it off a little, 1/6th of a turn, and assemble. If it leaks tighten it until the leak stops, not more. check it once in a while, it will be fine after one or two retightenings. Don't over tighten it will get hot. Jim
