Posted by Kerwin on September 08, 2010 at 05:37:40 from (204.54.36.245):
I was bench testing the 6V generator from my M and could get it to motor with the F terminal grounded, but it did not want to speed up when I removed the jumper from the F terminal. In fact, it will usually continue at same speed for a while and then slow down.
A couple of questions:
I was using a battery charger with a 6V/10A setting to provide power. Would using a fully charged 6V battery make a difference?
There is some back end noise in the generator, even after oiling. Could a bad bearing, etc., cause enough resistance to keep generator from picking up speed?
What else can I look for in the generator to determine cause of motoring problem? I did a search and found reference to a troubleshooting chart by John T, but not sure where the chart is located.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
