Usually a smooth even RPM when you jump voltage to the ARM post and case/frame (with FLD grounded) means the Armature, Brushes and bearings/bushings are in "decent shape" Then if it increases RPM when FLD is ungrounded that means the Field windings are at least intact. If she dont change RPM at all I question if the Fields are bad such as open or shorted internally. An ohm meter can provide an indication if the fields are open or shorted.
That noise may be a bearing/bushing "going" bad although it isnt bad enough yet to allow the armature to drag.
I prefer a battery for the motor test but still think it should act about the same as above unless the charger can barely supply enough amps to begin with.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
