Re: '47 ford truck won't start
Posted by Al L. in Wisc. on September 08, 2010 at 14:43:18 from (216.226.95.81):
In Reply to: '47 ford truck won't start posted by e-manhunt on September 08, 2010 at 14:20:33:
If you haven't already, I would also post the ? here:
http://www.yesterdayspickups.com/trforum/wwwboard1.html
In 1981 I purchased a 1951 Chevy 1/2 ton pickup, becoming the third owner. It would have the occasional problems also. Sometimes is was simply the old insulation getting wet or connections being so brittle, they would break and such things would mess up the flow of juice from the six volt battery to the spark plug electrodes. You did say no spark - Sitting two years, make sure all your connections are shiny, bright and tight; mice haven't found your pickup a buffet/lodging facility; coil; loose connections, i.e. coil wire-distributor-spark plugs; ignition switch corroded up; battery cable properly grounded. I also once had the fiber timing gear self destruct - HEY, after 40 years what is going on! Yup, it got tired. I had mine about 12 years, 'my little puddle-jumper' Good luck with your project.
