Re: Farmall Regular has hot spark and compression
Posted by oldiron29 on September 09, 2010 at 03:59:49 from (69.112.87.249):
In Reply to: Farmall Regular has hot spark and compression posted by Duanes on September 08, 2010 at 14:54:31:
Duanes, the E4a and the F-4 have different size drives! have you changed the shaft hud on the gear side? Yes the woodrif key may have come out or broke. Compression most be ok if tractor will run. You have a timing problem. I would start with #1 TDC and check all. If it is starving for fuel it will cough, but oil out the air breather
you got time problems. oldiron29
