Re: MD shut down issues
Posted by Janicholson on September 10, 2010 at 13:50:45 from (199.17.6.223):
In Reply to: MD shut down issues posted by BruceS. on September 10, 2010 at 13:29:39:
If the ignition is shut off, the engine should die immediatly. If it a Mag, the mag kill switch might be inoperative, or the manifold switch not working. If you turn off the gas, it will run for as much as a minute and sputter to a stop as it runs out of fuel. Turning off the fuel and letting it die this way is good if it is going to be a while between periods of operation. If you will be running it even weekly, I would shut off the fuels after shutting off the engine, leaving the gasoline in the carb. Jim
