Posted by redih on September 11, 2010 at 09:43:42 from (208.91.177.142):
In Reply to: farmall m remotes posted by Dan in Ore on September 11, 2010 at 09:05:06:
these are designed for ih cultivator 1 cylinder on right 1 cylinder on left i cylinder on rear optinal. hydralics will work a one way cylinder or a 2 way cylinder vented on the down side of the cylinder, the belly pump is designed for around 1100# pressure and is a one way system,you should be able to access any elbow that has pressure with with the lever in front of the belt pully pulled toward steering wheel.
Today's Featured Article - Field Modifications (Sins of the Farmer) - by Staff. Picture a new Chevrolet driving down the street without it's grill, right fender and trunk lid. Imagine a crude hole made in the hood to accommodate a new taller air cleaner, the fender wells cut away to make way for larger tires, and half of a sliding glass door used to replace the windshield. Top that off with an old set of '36 Ford headlight shells bolted to the hood. Pretty unlikely for a car... but for a tractor, this is pretty normal. It seems that more often than not they a
... [Read Article]
Latest Ad:
[More Ads]
