farmall m remotes
Posted by Dan in Ore on September 11, 2010 at 09:05:06 from (69.71.182.5):
I have a 1947 Farmall M. The remotes are hooked up to a couple of elbows on the right side of the belly pump. There are two more elbows on the left side of the pump. Are these remotes also and will they work the same as the ones on the right side?
Today's Featured Article - Talk of the Town: Repairin a Gas Tank - by Staff. This interesting discussion is from the Tool Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
