Re: farmall m remotes
Posted by Janicholson on September 11, 2010 at 13:15:50 from (67.72.98.45):
In Reply to: farmall m remotes posted by Dan in Ore on September 11, 2010 at 09:05:06:
third party image
As below.
The rear left elbow is a delay port, Ignore it.
The front two elbows are hooked to a "T" inside, so they are pressure up, and return on lower.
If using a two way valve, T into the bottom of the reservoir to make a return
Today's Featured Article - Talk of the Town: Repairin a Gas Tank - by Staff. This interesting discussion is from the Tool Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
