Re: 51 IH SC w Carter Carb UT#0-653
Posted by farmallhal on September 13, 2010 at 19:26:44 from (76.2.185.60):
In Reply to: 51 IH SC w Carter Carb UT#0-653 posted by oldmill on September 13, 2010 at 17:39:33:
I have a 1953 Super C that had a Carter UT carb on it and it was nothing but constant problems. Several rebuild kits later installed by a couple of carb shops and it just never would run right. I found a Zenith NOS carb for it at a RPRU from Justin Weber and it has been a top notch runner ever since. That was my solution to the Carter UT problem and if you choose to keep working with your Carter I wish you the best with your issues, Hal.
