I agree. If the Carter carb can be made functional again with a good cleaning and a rebuild kit, then by all means that is what should be done, but I would caution anyone that has a Carter to remove it from the tractor and open it up before you buy the kit. If the float is trashed, and cannot be repaired by soldering, then you may as well bite the bullet right now and find a Zenith or Marvel-Schebler. Both the Zenith and MS carbs are readily available brand new, and the price is not all that bad compared to buying a used Zenith that needs lots of work before it can be installed.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
