Re: Super A rebuild - How would you do it?
Posted by Red Dave on September 14, 2010 at 12:54:08 from (66.216.141.163):
In Reply to: Super A rebuild - How would you do it? posted by WellWorn on September 14, 2010 at 10:22:08:
3-1/8" High Compression pistons will give you a nice increase in power for very little expense, I would do that.
If your valves are OK I would not go to the expense of hardened seats unless you are replacing them anyway.
Some time and money spent going over the governor is well worth it. Fix or replace anything that is worn, loose, or broken inside it. Then set it up per the manual. A smooth, responsive governor makes a tractor a pleasure to run.
