Posted by WellWorn on September 14, 2010 at 10:22:08 from (74.84.253.27):
I have a '51 Super A that I inherited with a freeze crack from front to back on the left side (I hear it's a common problem). It was working ok for a while, but took to blowing oil from the head gasket and leaking anti-freeze from the bondo patched crack. It was also blowing compression into the crank case, and oil fowling plugs, so it really needed a major anyway - but not with a trash block.
I located a sound block, stripped and boiled for $500, and wonder how those who have 'been there' before, would do it from the ground up: High compression pistons? Flat tops? Standard 3" bore? 3 1/8? Are hardened valves and seats available for no-lead fuel?
Anything else you might think of?
I figure if I'm gonna do it, I may as well do it as right as I can.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
