Break-in oil for overhauled engine Farmall M?
Posted by LittleFarmer on September 14, 2010 at 18:29:51 from (74.46.121.177):
Just finishing-up on the engine overhaul of my Farmall M--new sleeves, pistons, bearings, etc.
Is there a recommendation on weight/grade of engine oil I should use for the break-in period?
Should I consider using synthetic?
This isn't a parade tractor---I use it to farm 160 acres and it does a lot of tandem disking.
Thanks for any advice---it IS appreciated!
