The grades mentioned below -- 15-40, 10-30 will work fine. I'd probably tend toward the 10-30 for the first coupla changes. I'd change the oil and filter out after the first 3-5 hours of run time just as a precaution, then transition up over the next couple changes to whtever interval your manual recommends. If you can find some work for the tractor to do, all the better to seat the rings. Once seated, you should not have nay smoke adn you shouldn't be able to detect any gasoline smell from the oil when you drain it.
At that point, I wouldn't mind the idea of going up to 15-40 or a synthetic. The 15-40 might work okay, too from the gitgo, but I would stay away from the synthetics until I'd run it for a while after I was sure the rings were seated.
Nothing scientific in my thinking. My thought stems from the guidance with the Cummmins in my Ram when it was new. Tey don't call for a break-in period for the motor, bu they STRONGLY recommend not switching to a synthetic until about 15,00 miles, when the motor has been well run-in and the rings seated. I know these IH motors don't have near the compression or tight tolerances of the modern Cummins. All I take from their advice is that synthetics don'st lend themselves to deating rings in a new/rebuilt motor.
Run dino at first, then switch off to synthetic later if all is fine.
No idea how much you plan on using the tractor, butif it's going to be light or infrequent, take the trouble and expense of running it long enough to heat up to "cook' any water from condensation out of the oil. Dino oil will emulsify with water from condensation. Again uninformed as to whether synthetics will absorb and emulsify with moisture in similar fashion. But bottom line, if not used and warmed-up regularly, condensation will build up in the crankcase and oilpan and, if not boiled-off/cooked out, will shorten motor life.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
