If you're going to work her hard and need extra power then go with the high comp. pistons. Otherwise I would just go with standard with the 1/8" overbore. I used the 1/8" overbore on my A and she now has 20HP (they were tested at 17 new). Hardened seats can be expensive and if she won't be worked too hard its not really worth it. Definately grind the valves. Be sure to seal her up real good. The aluminum blocks on the front and back of the motor around the crank like to warp and will leak. Lay them flat on a piece of sandpaper on a bench and sand em out till they sit flat on the bench.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
