Re: Working M, won't start, emergency!
Posted by Armand Tatro on September 15, 2010 at 15:26:50 from (71.239.9.235):
In Reply to: Working M, won't start, emergency! posted by Mr77FM on September 15, 2010 at 13:52:24:
Does this tractor have a live hyd. pump driven by the dist. drive. If so you may hav a broken cam/timing gear. To get to the the timing gears you have to remove the front bolster, radiator, crankshaft pully, and front cover. To get to a couple of front cover bolts they come off from the dist/hyd. pump side of the block. You need the front support stand of the splitting stand assy. to safly support the engine half of the tractor. Armand P.s. Let us know what you. find.
