Re: Working M, won't start, emergency!
Posted by El Toro on September 16, 2010 at 04:02:56 from (108.3.180.43):
In Reply to: Working M, won't start, emergency! posted by Mr77FM on September 15, 2010 at 13:52:24:
Hold your hand over the throat of the carburetor and see if there's good suction. You will need a helper to make an attempt to start the engine.
If there's not much suction means you have low intake manifold vacuum that's necessary to draw that fuel into the engine. Check your intake manifold to make sure it is tight and not leaking. I would do a compression check to see what that is and compare the readings. Worn sleeves and valves not seating can cause low intake manifold vacuum. Hal
