Re: M crank timing marks, Mag impulse
Posted by Theman on September 16, 2010 at 11:29:27 from (65.198.133.254):
In Reply to: M crank timing marks, Mag impulse posted by flatlander on September 15, 2010 at 22:03:36:
Does the serial number on the magneto itself happen to end in the letter 'Y'? If so, it won't work without changing the drive gear relative to the cam gear. It is for another application. The reason I know is that I rebuilt one that was configured differently than the H4 mag on my '47 Farmall H. The oddball mag had an impulse that snapped at 90 degrees after top dead center and was stamped XR by the drive lugs.
If this mag isn't what you have, your drive timing is off. Worst case: Your cam gear nut has loosened and allowed the gear to get out of time.
By the way, the third mark on the front pulley is to line up the pilot bearing Alemite fitting on the perimeter of the flywheel with the hole in the bottom of the clutch housing when greasing the tractor.
