Re: M crank timing marks, Mag impulse
Posted by flatlander on September 19, 2010 at 21:54:56 from (8.20.214.112):
In Reply to: Re: M crank timing marks, Mag impulse posted by Theman on September 16, 2010 at 11:29:27:
I got a chance to work on the M today. I compared the mag drive gear position at tdc to my H. It was off. I removed the valve cover and checked the valve/cam timing. It looked good. I found the mark on the cam gear with a mirror and lined up the mark on the drive gear with it. I got it to impulse at tdc the way it should. One of the mags had the rotor out of time so I had to get that right. I got it to run using both of the mags. Thanks for the help
