Re: Stanadyne injection pump question
Posted by Bob on September 16, 2010 at 12:01:50 from (69.178.228.68):
In Reply to: Stanadyne injection pump question posted by Tom/Idaho on September 16, 2010 at 11:23:01:
Having a flow of fuel at the fuel return fitting AND having the fittings on the injection lines "cracked" loose should allow the system to bleed.
Sometimes it takes a while. If you can have a helper pull the tractor around a bit it will save in the starter.
Otherwise, the metering valve and/or the pumping plungers in the IP MAY be stuck.
