Stanadyne injection pump question
Posted by Tom/Idaho on September 16, 2010 at 11:23:01 from (216.57.174.229):
656 sat for about 6 months while all the fuel drained out of a small hole in the bottom of the primary filter. Replaced the filter canister and bled the tops of both filters and have fuel coming out the return line in top of pump. Can get only a few bubbles out the injector lines at the injectors. Will not take enough fuel to the injectors to start. Will only fire a time or two on very small shots of ether. Owner says it ran fine when shut down 6 month ago. Is there a bleed screw on the injection pump?
Any suggestion will be appreciated. Thanks, Tom/Idaho
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
