Re: M wide front
Posted by D Slater on September 16, 2010 at 14:23:11 from (184.15.13.17):
In Reply to: M wide front posted by rustyfarmall on September 16, 2010 at 12:36:40:
Codave, What kind of steering arm is on the steering shaft, the left side tie rod looks like it has way to much angle from steering shaft arm to the spindle steering arm. Or maybe the tie rod is installed wrong.
Have to disagree with Rusty, the left and right spindle shaft steering arms are the same with the same part # on that wide front, 358971R1.
The spindles are different left and right. If no aftermarket parts installed you may be able to find IH numbers on the wide front parts, on the bottom side of steering arms, on the frame support, near bottom of spindles. Spindles numbers will probably identify what tractors the wide front was used on. Probably if you look at caseIH parts online a 560 or 460 wide front will have most parts like yours. The knees or the part the spindles come up through looks to short in the picture to be from a SMTA, 400 or 450. Picture of actual steering arms. third party image
Today's Featured Article - Allis Chalmers ED40 - by Anthony West. Allis Chalmers as a tractor manufacturer in its own riht is but a memory. However the number of AC tractors still in existence today as either restored or unrestored examples is a testament to the quality of their products. This in itself is always apparent here in the U.K when attempting a purchase, as no matter what the model or condition the price will always be strong. ... [Read Article]
