Posted by CoDave on September 18, 2010 at 15:48:29 from (208.68.48.120):
In Reply to: Re: M wide front posted by D Slater on September 16, 2010 at 14:23:11:
Okay, it looks like this is a front end from a 460. The left and right knuckle assemblies (spindle) have P/N 370367R1 which identifies them as from a 460 adjustable front axle. And you're right the steering arms are the same on both sides (also same steering arms as on 560). The tie rod angle you mentioned I can't explain. That tie rod is installed the same as the one on the right - the difference is just the up slope of the arm on the right side and the down slope on the left (but the left arm appears to be the correct one). I'll have to find the correct arm for the right side I guess. I'll check with Case first and then see if I can find a used one if the part is no longer available.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce
... [Read Article]
Latest Ad:
[More Ads]
