Re: Farmall M Final Drive Rear Axle Bearing Questions
Posted by rustred on September 17, 2010 at 20:47:57 from (74.198.148.45):
In Reply to: Farmall M Final Drive & Rear Axle Bearing Questions posted by keithg on September 17, 2010 at 20:15:48:
if you only have .010 of play i would keep running the brgs. but of course remove the cap and give them an inspection to make sure they look ok also. the seal should still seal ok. just for running around still will be good for years.
Today's Featured Article - Talk of the Town: Repairin a Gas Tank - by Staff. This interesting discussion is from the Tool Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
