Posted by keithg on September 17, 2010 at 20:15:48 from (173.28.129.191):
I am currently working on a 47 M and looking at the inner/outer rear axle and bull pinion (brake) shaft bearings. I am curious how some of the forum members make the judgment call about replacing or reusing these bearings.
For example, I removed the entire wheel from the RH rear axle, placed a dial indicator on the axle next to the outer grease fitting, then raised and lowered the rear axle by hand............saw about 010" of movement, I assume due to original bearing radial clearance+wear in the outer bearing. Is this enough play to consider replacing this bearing? And will this amount of play prevent the new outer axle oil seal I am planning to install from actually sealing? Some of these bearings are expensive, at least through CaseIH.
I have the transmission cover off now so I can easily access all of these bearings. Tractor will be lightly used in the future, only rarely seeing full tractive load.
Thanks in advance for any pointers which may be provided.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
