farmall 460 hyd system overheating and surging
Posted by redhot on September 20, 2010 at 13:06:38 from (66.225.148.67):
The tractor runs fine but after 45 min to 1 hour the transmission case gets hot and the hyd pump seems to be blowing over relief. So I took the pump regulator apart and found the orfice plug for the unloader valve was plugged. so I unplugged it,clean and checked the other valves in the regulator and assembled regulator. Ran tractor found no difference. I checked the other control valves for proper one or two way flow detent postions, they were okay. Installed two new suction filters. Ended up taking out the spring for the unloader valve in the regulator. this seemed to stop the problem, but do not have hyd pressure for remotes. I would like some help to find root cause for the problem.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
