Question, you stated you took the orfice plug out and cleaned it in regulator valve assembly. Did you cut the end of the screen off so you can clean completely and then roll it back up a bit. Also, did the orfice have a roll pin in head, if so there is a ball under that pin and it bounces back and forth over time and peens the hole undersize. They are hardened and very hard to drill out but I have done it. Just did it to a 560 couple of weeks ago. The original size of hole is .031 so not very big. As the regulator lands on the aux valve and especially the teledepth valve if it has fast hitch wear, they allow more oil to flow past them than what the orfice can supply to regulator piston there fore you go on demand and system will of course heat. I have drilled many over size but it is trial and error. Too much and you have no hydraulics. I would strongly recommend you put a gauge in port right on main pump to observe regulated and relief valve pressure. Often times they will work fine until warmed up and then go on demand and stay there.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
