calling Gene Bender - carb adjustments ??
Posted by couv on September 21, 2010 at 18:39:48 from (173.30.181.225):
Re: farmall c carb in reply to jim from az, 09-21-2010 13:08:53
Without the gasket float should be parallel with the body and measure 1 5/32 +- 1/64 this is factory setting from ZENITH
Gene, you posted this reply about a"C" carb --
exactly "how" does one measure the 1 5/32 +- ?? Carb right side up (or upside down)?
No gasket -I get that.
But what is "Point A" and "Point B" , between which should measure 1 5/32 +- ?
A picture or drawing would help all of us greatly.
