Re: calling Gene Bender - carb adjustments ??
Posted by bc on September 22, 2010 at 13:26:07 from (68.92.138.114):
In Reply to: calling Gene Bender - carb adjustments ?? posted by couv on September 21, 2010 at 18:39:48:
I don't think the float setting is all that critical. I just eyeball it to see if it is parallel. Otherwise I use a tape measure that only reads to the 16th of an inch and leave the calipers in the case. I'm more concerned with the little tab that limits how far it drops. I don't want the float dropping till it hits the bottom of the bowl or else it might get stuck. Hopefully the bowl will always stay full except when you go petal to metal. But then final flow is restricted by the idle jet and the main jet setting.
