Posted by Farmall Dann on September 22, 2010 at 12:02:54 from (96.60.16.231):
Went to rebuild a 460 with a c221 engine. when some thing did not look right pulled the head no sleeves. Was told its a combine engine. Are the connecting rods the same? Are the pistons the same?Are the heads the same? Camshaft the same? Is the carb the same Governor? manifolds? distrubtor? What all interchanges with a c221 sleeved engine block. Thanks!!!
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
