Re: 303 C221 engine
Posted by Owen Aaland on September 22, 2010 at 16:03:49 from (207.13.114.39):
In Reply to: 303 C221 engine posted by r4etired on September 22, 2010 at 12:02:54:
I made that swap on a 460 about 20 years ago. The engine I used came from a 315 combine. If you have trouble getting oversize pistons you can have the block bored to accept the tractor sleeves.
Everything except the cylinder sleeves will interchange. The blocks are the same except for the lack of sleeves and the rear mounting holes are not threaded, you need to use a nut on the engine side. If you were to buy a new service engine or a new block, the sleeveless block is what you would have gotten from IH. The carburetor may have been different if the air intake pipe came in from the front of the engine rather than the rear. The exhaust manifolds are different on the combine. The combine used a different oil pan. The front cover and plate are different. They mount differently and the combine had a hydraulic pump mounted to drive of the front gear set.
