Re: Farmall A generator
Posted by John T on September 23, 2010 at 04:44:04 from (66.244.97.31):
In Reply to: Farmall A generator posted by Dahlin on September 23, 2010 at 04:20:15:
NOOOOOO you dont drain the battery, its still a battery with a + and a - terminal REGARDLESS which post just happens to be bonded to a huge chunk of rusty old iron......
A genny can still charge a battery, again REGARDLESS which post is tied to the tractors frame and whether one uses that frame as a return current carrier wired to the + or - battery post.....
That being said, if you want to reverse battery polarity by changing which post you tie to frame ground ( + or -) all you do is reverse the battery THEN BEFOREEEEEEEEEE YOU START THE TRACTOR POLARIZE THE GENNY by using a lil jumper wire etc to momentarily flash/jump from the BAT terminal on a Cutout Relay or a Voltage Regulator over to its GEN/ARM terminal and you should get a spark. THAT ANSWERS YOUR QUESTION YESSSSSSSS YOU SWITCH GENNY POLARITY BY RE POLARIZING IT AS ABOVE
If it has a working ammeter (and you change battery polarity) its leads need swapped or else it reads bass ackwards.
Got it??????????????
John T
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
