Re: Farmall H Voltage
Posted by Janicholson on September 23, 2010 at 16:58:43 from (67.72.98.45):
In Reply to: Farmall H Voltage posted by Chris Sw on September 23, 2010 at 15:33:33:
13.8 volts is way high for a 6v system, if you have turned on your lights and they didn't blow out in 10 seconds, the battery might be 12v and it might be a 12volt system. If the battery has 6 cells (six holes to put water in) it is a 12v battery.
Check the voltage with it turned off. (I bet it is 12volts. Jim
