Re: Farmall M Brake Drum Grease Seals?
Posted by Melvin Ware on September 24, 2010 at 17:58:29 from (4.88.48.246):
In Reply to: Farmall M Brake Drum Grease Seals? posted by Melvin Ware on September 24, 2010 at 12:52:12:
Thanks for the help guys - that's the information I was looking for. Also, do I understand correctly that the replacement seals are sized to install directly in the bore of the bearing cage without the sleeve used with the dual seal assembly? Also, if I decide to use just a single seal as has been suggested, any there any tips for installing the seal so it runs on an unworn portion of the drum? I'm a novice at this and learning as I go.
