Posted by Melvin Ware on September 24, 2010 at 12:52:12 from (4.88.50.219):
Anyone have part number(s) for replacement grease seals for brake drums used on a 1951 Farmall M? The old one I removed (mangled in the process) is a two-seal assembly comprised of two grease seals separated by a thin metal spacer and all enclosed by an outer sleeve. The part number found on the back lip of the sleeve is C/R 45073-D. No part numbers on the seals but they look identical.
I read somewhere on this forum that the dual seal assembly is no longer available and when replacing, one must now install two separate seals. Without the sleeve, the seals will need to have slightly larger O.D. than the original seals that were contained in the sleeve.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
