Need Help Understanding/Reading Engine Stampings
Posted by AL Farmall Boy on September 25, 2010 at 16:36:59 from (98.83.136.153):
Here are the stampings for the engine serial number and whatever else for my Cub. I am trying to read this and its very faint and not easy to see with stuff in the way. I cleaned it with Acetone, and rubbed some chalk over the stampings to bring them out, and this is the result I got.
To me it looks like it shows 2 lines of information.
The top line looks like it says " F C U B M "
The bottom line looks like " 2 8 9 0 "
Someone please tell me if this is correct. Take a look at the pictures to check my readings.
¢À Is the " 2 8 9 0 " the engine serial # or the RPM of the engine??
¢À Should there be any more numbers on the top line??
¢À What does the " M " stand for??
