Need help wiring a Farmall H
Posted by ZB Hay Farm on September 26, 2010 at 12:20:09 from (99.71.254.109):
Need some help on a 1940 Farmall H. Bought in the midway restoration phase. A 4 wire harness is hanging there, one wire to the mag, one to the starter solenoid, one to the battery, and the fourth is just taped up and tucked away. It is going to a two sided push button switch. Looked at the book I had for old farmalls but they do not have a diagram. Should the mag wire go to ground, the solenoid to the voltage side. The battery wire already runs to the voltage side of the battery, Does that sound right? If I touch the mag and solenoid wires together I get it to turn over. By the way it had a 12 V battery in it, folks told me that will work fine to start it. Thanks.
