Re: Need help wiring a Farmall H
Posted by gene bender on September 27, 2010 at 01:50:13 from (67.55.227.196):
In Reply to: Need help wiring a Farmall H posted by ZB Hay Farm on September 26, 2010 at 12:20:09:
You have a huge mess first there wasnt any starter soleniod on any H. The wire going to the mag goes to single pole sw which is ground when sw is closed. What kind of a generator and regulator do you heve. No wonder you cant find a dia for your system better just start opver and rewire one thing at a time. You must not have a meter or you wouldnt have touched the mag and sol wire together. Your advise was also bad you need someone who does realy know what they are doing. These things happen all the time redoing wiring gets real messy pput it back to original and then it will work as i did when it was new.
