806 stuck in fourth gear
Posted by theponyroper on September 28, 2010 at 05:18:05 from (199.154.117.32):
I found an 806 on a local website for $2,200. The seller says it starts and runs excellent but is stuck in fourth gear. It has a Schwartz loader, Cozy-Cab, block heater, rear tires are 80%, front tires are new. How much of a problem is the stuck gear? My old 560 shift was so worn it always slips out of the splines and I have to take the shift out and realign the splines to get it to shift again. Takes about 5 minutes. Is this the same problem the 806 might have or is it something much more complicated?
