Re: Mag not firing
Posted by John T on September 28, 2010 at 08:59:20 from (66.244.97.31):
In Reply to: Mag not firing posted by E.Frank H. on September 28, 2010 at 08:44:21:
Im not into IHC Mags whatsoever, buttttttttttt generally speaking the FIRST SUSPECT is points that are burned or pitted or carboned over NOT stuck shut as you asked. Often a good smooth buff down n clean n polish using a points file etc will get them running (or run a dollar bill between them if theyre only oxidized over) buttttttttttt if they are badly burned or pitted its time for a new set. Other problems may be the condensor or if it has any sort of push kill switch a short can develop which kills the spark deader n a doornail. The IHC mag gents can get you going I bet
John T
