Re: Backlash
Posted by pete 23 on September 28, 2010 at 10:17:07 from (173.87.17.162):
In Reply to: Backlash posted by CNKS on September 28, 2010 at 09:40:25:
Those little tractors are difficult to get a good reading off due to their location. That being said though, I would sure set it back with the same shims on the pinion and diff if at all possible an even then you will be on a slightly different spot on the gear due to the looseness that develops in bearings as they wore. It is a science to set them gears using prussian blue or other markers that not very many people can do well, including me.
