Backlash
Posted by CNKS on September 28, 2010 at 09:40:25 from (216.144.104.128):
I disassembled my Super A transmission to replace the bearings. I need to set the backlash of the ring and pinion. With the countershaft and differential installed it appears next to impossible to measure the .005-.007 required backlash because the housing, etc is in the way and I can't see or feel what I am doing -- the only possibility I see is to take the side and pinion gears out of the differential (really don't want to), then perhaps I can get the ring and pinion in the correct position to measure -- perhaps not. There seems to be excess play, as it is easy to feel a "click" as I begin to turn the gears. Any suggestions?
